Old 01-28-2014, 11:09 PM   #5
Steve Tinker
Steve Tinker's Avatar
You guys are lucky - on R/H drive cars. the switch holding screws are reversed with the slotted head @ the top where you cant see them.......
I'm reasonably small but no way could I get under the dash, see where the screw head slots were orientated to fit the screwdriver (shortend to about 3" long to clear the dash) & then hold a pair of pliers to rotate the scredriver !!
In the end I removed the dash air vent and went in from the top where I could see the screw heads to undo the ignition switch.
Any person with big hands will have a major problem going in from the bottom.....
2001 MV Agusta F4.
