I replaced mine in 13 minutes and could have done it a lot faster. The hard part is you can't get your arm in a position to have any real leverage. My solution was to use both hands. With my right I held the screwdriver in place and pushed firmly in toward the screw. With my left I used a pair of pliers to grip and rotate the shaft of the screw driver. The inward pressure on my right hand was just to keep the screwdriver in place and avoid stripping the screw. Without using two hands (and the pliers) I can't see how one can get enough leverage to get the screws off.
