Old 02-20-2006, 04:22 PM   #2
MNBoxster
Originally Posted by blinkwatt
After a long wait my new MAF has finally showed up. After installation I started the car up and noticed the idling was bouncing around a tiny bit. The car ran pretty darn good after I installed the new MAF,no hesitation as reported before. After a spirited drive I pulled in the driveway and the car idled fine. Does the DME adjust to the new MAF,is that what caused the funky idle?
Hi,
Did you disconnect the Battery before swapping out the MAF? You should have (ALWAYS disconnect the Battery before doing ANY electrical work on the Car, or you could need to add a spendy, new, DME to your Parts List!), and I assume you did.
Such being the Case, then yes, it's the DME's Adaptive Memory which was wiped out and then had to relearn, in the interim, it switches to a Default MAP. It will continue to learn for a Drive Cycle or two. Good Job!...
Happy Motoring!... Jim'99
