I think you said YOLO at one point in reference to this engine cover. Just for that, I think I'm required to order 10 minimum.
When we waited in Taco Bell drive through line, the cover warmed up, BUT it wasn't hot. The thermometer readings will put this concern to rest.
The sound increased, because the heavy sound and heat damping carpet was removed. The sound level equivalent would be to remove the rear shelf and remove the carpet cover while leaving the engine hatch cover sealed. Shehadehd's engine cover seals the compartment just like the oem hatch cover.
Would your kit come with the lights? I need me some of those
