Old 01-15-2014, 08:55 AM   #10
Jake Raby
Engine Surgeon
Originally Posted by healthservices View Post
I really wonder if the motor is a interference motor when the instructions tell you to just rotate the motor 360 with no regard to cam position?
Trust that it is a heavy interference engine.
Not rotating the engine when setting cam timing only phases both banks of cylinders simultaneously.
This creates two 3 cylinder engines and the engine would run if it had batch fire injection and a wasted spark ignition system.
That sound on the starter tells the entire story when this occurs.
US Patent 8,992,089 &
US Patent 9,416,697
