Thread: Winter Storage
Old 01-13-2014, 03:27 AM   #20
Nimbus117
Nimbus117's Avatar
There is a good reason to disconnect your battery, corrosion. Just having the battery connected will cause anything connected to earth (body, components etc) to corrode quicker than it otherwise would. Sure this corrosion is probably infinitesimal over normal, this isn't the reason my battery is kept inside during winter - just easier and better for battery life.
I have no problem disconnecting the battery when doing work on the car, DME will only ever learn from 'safe settings'.
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
