Old 01-11-2014, 04:22 PM   #10
scottvd
scottvd's Avatar
I installed the Suncoast LED kit today - everything fit fine in my 2004 S. The two 41mm bulbs were for the trunk/frunk, single 30mm for glovebox, and the three 194LED push-in bulbs went in the doors and dome light.
I used a credit card to remove the dome light lens (shown in first picture) -- slipped it between the lens and bezel and it popped right off. I thought any metal screwdriver would mar either the plastic lens or the surrounding bezel. It appears as though the lens had a thin layer of clear glue holding it on - when I replaced it after the LED upgrade I used just a tab of super glue to keep it locked into place. Not sure if this is standard or something from the PO.
As a side note - the 194LED included in the Suncoast kit is the maximum height that will fit - anything taller would be too long for the lens to fit. And the LED upgrade makes the car interior look great - super updated look. Glad I did this!
2004 Boxster S
scottvd is offline   Reply With Quote
