Old 01-01-2014, 04:15 PM   #1
Walter White
You can also consider making them from light weight plastic. Check out Foam Core PVC or Foam PVC sheet from Tapp plastics, 1/8". It is very light, easy to cut with saw or shears, heat with a heat gun to bend. If they hit something, they will just shear off without breaking anything under your car or cutting a tire. And they won't be a real hazard for anyone behind you.
Make them real short, then extend them with sheet rubber and pop rivets.
It's all bad
Walter White is offline   Reply With Quote
