				2013 981S - 18" wheel for DE
			The 2013 981 specifies the following wheel combinations:235/265 35 20
 235/265 40 19
 235/265 45 18
 I just bought a set of 2009 Boxster S III 18x8 18x9 wheels and wanted to use 18" for Driver Education to save on the cost of 20" tires.
 At issue are the following:
 1) Seems the there are only 3 tires available in the 235/265 45 18 size
 2) Two 2 national tire companies that if I deviate ABS and PASM will not work
 3) Going to 18" will not ventilate the brakes adequately. Larger calipers on 981S
 Question:
 1) Can I move to a more tire friendly size, recommendations?
 2) Will the ABS and PASM work?
 3) Suggestions on tires that are DOT legal so I can change tire at home, then go to DE
 4) Any truth to ventilation issue with smaller rims and calipers?
