Thread: Hokey video
Old 12-29-2013, 03:41 PM   #1
Spinnaker
Spinnaker's Avatar
Be wary of putting the top down in cold weather. A lot of new owners of the older models with the plastic rear window, learned the hard way that the window is brittle in cold weather and can crack when you put the top down. You shouldn't put the top down when the temperature is below 60º unless you run the defroster and heater for awhile to warm up the plastic window. Use a rolled up towel in the fold of the window to keep the plastic from folding in a sharp crease will help keep it from cracking and getting a crease mark also.
