Old 12-24-2013, 02:29 PM   #1
Steve Tinker
Steve Tinker's Avatar
Originally Posted by Yellow986S View Post
When I am ready to tighten the lower control arm bolt and torque it the car needs to be on level ground with the full weight of the car compressing the suspension right?
So how would I tighten the bolt if I cannot crawl under and fit?
I was thinking about placing 2x4s under all 4 wheels.
Thx for the tips and what is the best way to go about removing the rear shock?
You are right - how do you tighten the suspension bolts with the car lowered on its wheels and not enough room underneath?
2x4's will work OK but still tight to use a torque wrench. I didn't have any 2x4's handy when I was installing my PSS9's and it was Sunday evening. So when everything was assembled but not tightend up, I jacked the individual wheel up untill the suspension was loaded (simulating the cars weight was on the suspension) and then tightend up the suspension bolts.
2001 MV Agusta F4.
