CONTINUED--
ATS SUPERBLUE $35
emerg. springs 50
Akebono FR pads 106
" RR pads 95
brake lines/ holders 108
caliper bolts
TOTAL $1242
CLUTCH REPAIR, REPAIR:
release bearing $127
2 pilot bearings 40
bolts 30
trans oil 85
assorted parts 220
TOTAL $502
REFINISH WHEELS:
bead blast 1 wheel center $40
spray booth rental 100
refinish supplies 272
mount tires on wheels 75
TOTAL $487
ASSORTED:
Complete cut and polish--
sandpaper, compounds $105
Cat bypass pipes(TOP SPEED) 279
muffler clamps/ bolts 85
hinge repair kit (center console) 29
DRL relay 71
fuel pump/ gasket 565
oil fill hose 40
tensioner pulley 86
engine oil (Motul 8100 20 L) 212
oil filters (2) 32
magnetic drain plug 26
air filter 28
cabin air filter 63
997 short shifter 352
2 Michelin Pilot super sports- Fronts 465
TOTAL $2437
ASSORTED TOOLS:
triple-square socket set
power bleeder
fuel pressure tester
flywheel lock
soft socket
Durametric
remote clamp removal tool
heli- coil kit
APPROX. TOTAL $600
GRAND TOTAL $7687
