Old 12-23-2013, 08:30 PM   #3
BYprodriver
BYprodriver's Avatar
Originally Posted by davedeck View Post
Got the Boxster back this past weekend and drove to work today(52 miles). Added a little coolant at noon before going to lunch. Drove home, slow flashing light on temp gauge but held steady at 180. The road iced upso I drove slow the last two miles home and the temp went up to 210. By the time I pulled into the garage, steam was coming from the right front wheel well and had that nice anti-freeze smell. Thoughts?
Does the system need a better way of bleeding? What's a Uview?
Make sure the bleeder valve is open. Sounds like you had a airpocket in the coolant passages that burped out when the temp got to hot.
Uview is a vacum filling tool that should prevent air pockets in coolant passages during initial fill. Any shop doing this work should use it to prevent what happened to you.
