I've used both Dimple and LN Engineering magnetic drain plugs, they both work well as long as you TORQUE them to the proper setting.
I over torqued the LN Eng. plug and snapped off the shoulder of the plug BUT I didn't harm the drain pan, so maybe its a good weak link. Plug replacement is cheaper than pan replacement.
The Dimple plug is a more robust plug with a hex head and I'd guess i could damage the oil pan if I wasn't paying attention.
