Old 12-20-2013, 10:52 PM   #17
com3dorm3
com3dorm3's Avatar
- Sachs Clutch Kit $330.00
- (2) 911 993 Carrera Sport Classic BBS Rear Wheel - 17x9 $500.00
- Power Steering Fluid $15.00
- Wheel Painting supplies $35.00
- (1) Spark Plug Tube, (6) Tube Rings $40.00
- RSS Underdrive Pulley + Belt $210.00
- (2) Power Steering Fluid (2 separate purchases) $30.00
- Aluminum Jack Pads $60.00
- Power Steering Reservoir O-Ring Seals $14.00
- JIC Cross Coil-Overs (Used) $450.00
- Aero Wing - Rear (Used) $130.00
- (12) ACS Race Studs 14X1.5 65mm $62.00
- H&R 30mm Wheel Spacers $160.00
- Auto Paint $38.00
- Inner Tie Rod (Deeza Chassis PO-A601) $24.00
- Porterfield Brake Pads (set) R4 $290.00
- OP Brake Rotors (Front/Rear) $135.00
- Brake Caliper Paint $12.00
- Gas Cap $17.00
- Brake Caliper Decals $16.00
- (3) Motul Brake Fluid $57.00
- TechnoBrace - Rear Cross Member Suspension Brace $104.00
- EBS Oil Sump Baffle $237.00
- (5) Motul 300V 10W-40 2-Liter $145.00
- Red Line Gear Oil 75W-90 $27.00
- Transmission Plug Tool $6.00
- Headlight Bulbs (2) Sylvania H7 $41.00
- Hardtop Spinlocks & Bolts $96.00
- Engine Mount $124.00
- Gauges (Oil Temp and Oil Pressure) $265.00
Total $3720
I hope the list for for 2014 will much shorter containing mostly tires and track fees
2000 Boxster S
com3dorm3 is offline   Reply With Quote
