Old 02-16-2006, 04:46 AM   #18
Tony W
Originally Posted by blinkwatt
Pep boys sells a oil filter wrench that works perfectly for a lot less then Porsches. The part number is A251,just call and see if your local Pep Boys has one. I beleive it was only $2.51.
You should also bleed the clutch while you are at it. I is supplied by the same resevoir. Very awkward to do this without a power bleeder.
Tony W is offline   Reply With Quote
