Old 12-18-2013, 02:00 PM   #1
silver-S
2002 Boxster S
I got these codes when my air-oil separator went bad. Simple test: if you can't get the oil filler cap off when the engine's running, that's your problem. The bad AOS puts a fierce vacuum in the filler tube. You may see a big burst of white smoke on starting, but I've also seen a Boxster trailing a faint stream of burning oil smoke that the owner was probably unaware of. Worth checking, in any case, since it's an easy test for a common problem.
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
silver-S is offline   Reply With Quote
