Old 02-14-2006, 09:16 AM   #2
MNBoxster
Originally Posted by bmussatti
Adam, good link! Thanks. Have you used these? If so, how long do they last??
Bill,
These theoretically never wear out. They are just sacks of salts which absorb the moisture in the Air. After a season's Use, you can place them in a Microwave for 4-5 min. which will drive all the moisture out of them. Then, immediately place them in a ZipLok for next season. It's probably not a bad idea to microwave them once again just before reuse to insure that no moisture seeped into the ZipLok. I have used the same bags for nearly 10 years following this method and they're still totally effective. BTW, you can find similar dessicant Bags MUCH cheaper if you look around. Hope this helps...
Happy Motoring!... Jim'99
