Old 12-07-2013, 08:19 AM   #2
trimer
jakesbox
trimer's Avatar
My $9.99 Harbor Freight Torque wrench has (apparently) failed. I discovered this when I just stripped the oil drain plug in my FJ Cruiser with the wrench set to 30 ft/lbs. So then I decided to test it on another bolt (that holds the hood latch on) and snapped it off. Luckily I had a second Toyota drain plug to use... And there is a second bolt holding on the hood latch... fun project for the day, try and get out the snapped bolt and replace it...
Note to self: If it feels wrong, STOP!
I am looking to get a new non-harbor freight torque wrench, any recommendations? The one I was replacing was 1/4 drive and went to over 100 ft/lbs. Maybe it is just finicky at the lower ranges? Maybe I should get a 3/8?
Steve
I use the Pittsburgh brand from harbor freight...have both 3/8 and 1/4 and have not had any issues yet...but I don't use it a lot. Maybe you just got a bad one?
