Old 12-03-2013, 09:21 PM   #8
Vista glass
Vista glass
Vista glass's Avatar
Tank replacement complete
Wow that was a chore. It would be easy if it were not for the elusive fourth hose.
I cannot believe some brilliant german engineer has not re designed that fitting to come into the trunk. An"S" pipe and a 90 on the tank mold and it's done.
It would be so efficient since the tank could be replaced in less than an hour from the trunk side.
I studied up and ordered parts.
Once begun I modified the procedure so that hose was the only one to test my patience.
I cut the oil filler tube.
The PVC cutters sliced it nicely.
They do not create debris that could contaminate the lubrication system.
I used industrial heat shrink when putting it back together.
The oil fill tube is an odd shape so the heat shrink conformed nicely.
I have not received any CEL's or had any vacuum type performance problems indicated in the 100 miles since the repair.
I did replace the elusive fourth hose as I cut the old one off to aid in removing the clamps and tank.
Getting the new hose on was the trying part.
I replaced many of the spring clamps as well.
I replaced the level sensor as well (since I was in there.).
As you can see I did label the tank, the hoses and the manifold so the fluids now go where they always went.
A red china marker worked very well on all of the materials.
I moved the clamshell up and out of the way to provide more access to the engine bay.
I taped padding onto sharp components that were gouging my flesh
I did a little housekeeping while I was recalculating
The tank replacement job was the PITA that has been documented,but with patience, some tools and a snifter or two of a good single malt it can be done!
Yes I will need to go to confession for the things I said about the engineer that thought this was a good design
Thanks for all the information and tips on the tank replacement.
The weather has been spectacular! Dropped the top and I'm on the road again.
Vista glass is offline   Reply With Quote
