Old 11-26-2013, 08:25 PM   #5
Kirk
DONE!!! This wasn't meant to be a detail by detail description of the install. That's all covered in those 65 pages of instructions! But I've highlighted some of the important parts of the install. I got the DOF flange on and the oil line run to the oil pickup point. It's tight to get in there, but I got it. It was easier for me to thread the hose onto the adapter at the oil pickup first and leave it just one turn from fully tight. I could then thread in the adapter and do the final tightening on the hose. I also installed a new RMS seal. Before running the car I rotated the crank several times to make sure that timing was not off so bad as to cause a valve to hit. Finally I installed the flywheel and ran the car to make sure I did not have any leaks. Looked really good!
I bought the Spec clutch from Pelican and I had called them to see exactly what the clutch kit came with as the on-line description is vague. Pelican customer support told me it was only the clutch and pressure plate. But while I had been waiting on their return call I called Spec directly and confirmed with them that their kit also included the pilot bearing, throw out bearing, and alignment tool, which it did.
The pilot bearing included in the kit though was a 6002Z bearing of unknown quality. The Z means that it has metal shields whereas rubber seals would be better in this application. The stock pilot bearing for my 2003 996 C4S was bigger, it was a 6202 bearing with rubber seals. As luck would have it I had a few of these in my shop as it's the same bearing that goes into air cooled 911 steering racks and I had just recently rebuilt a steering rack. So I installed a SKF 6202 2RS JEM bearing - same as stock, but better quality.
I've driven the car now without any issues. As the weather is finally getting colder in Texas I will probably be putting up my 914 daily driver (it has no heat or defrost) and driving this car more. A check of cam deviations with my Durametric tool showed normal, which means I didn't screw up and skip time on the chain with the install. I also don't have any oil leaks. My stress test was to run the car up to 140 MPH, which it did without breaking a sweat. I need to break in the clutch though before really abusing the car, which I normally do as a matter of course, not just for testing.
Overall I am very pleased with the quality of the parts in the DOF kit. The install is certainly time consuming, but not really that challenging. Again, the hardest part for me was just getting the darn transmission out of the tight hole it was in! Installing the DOF was pretty straight forward in comparison.
Now, will I install one on my 2000 Boxster S??? YOU BET!
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
