I installed ROW M030 and slotted the hole in the mounting flange thereby allowing me to lower the strut .75" in the hub. I had massive toe-in (and bump steer) and after much investigation, ended up buying Top Speed's adj. toe links ($275). This allowed me to get the toe in spec and the camber is at -1.5 at the min. setting and have driven it 6000 mi. with no signs of a bad wear pattern. The eccentrics have a narrow range of adjustment. I have a thread in this section with Brad Roberts ( pro race car builder including many Boxster builds) helping diagnose the problem.
