Old 11-25-2013, 11:27 AM   #1
jimk04
H&R lowering springs on ROW S
Ive fitted these springs to my car and they have lowered it approx 30mm.
I am experiencing rear bump steer, although to be fair it did a bit before hand.
So I need to have an alignment done and make the rear toe more parallel to stop the bump steer, but then I understand that the camber goes more negative.
So my Q is do you think I will be ablt to get parallel toe and reasonable camber with the standard suspension links?
I want to get rid of the bump steer, but dont want to end up with masses of camber that will wear my tyres out!
Any input appreciated
jimk04 is offline   Reply With Quote
