Old 11-25-2013, 03:38 AM   #1
Dragonwind
Lots of choices if you run a narrower tire on the rear. Anything from 225-255 will fit on a stock rear wheel. As long as the outer diameter is nearly the same (25") you will be fine. I often run a 225/45/17 on a rear wheel to good effect and a narrower tire offers better hydroplane resistance in rain and snow than a 255.
I wasn't aware you could reduce the width and actually get it to fit on the wheel. Interesting.
If you're not driving in the snow, I think 4 season tires will give you a better choice/performance result. Less noise than real snow tires too.
I was thinking that too. Then the transition is a little smoother and if I get caught in a light snow, which has happened, I will still make it back fine. I drive it a lot but have a Tacoma which got me through las year and snows on my Rabbit.
Chris
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
