Old 11-23-2013, 01:20 AM   #1
Steve Tinker
Steve Tinker's Avatar
Try resetting the ECU base parameters..
1) Disconnect battery again after removing ignition key.
2) After reconnecting battery, put key to IGN so dash lights up - but don't start engine.
3) Leave in this position for ~60 seconds.
4) Switch off ignition and remove key for ~ 10 seconds.
5) Start car as normal - the base parameters should have been reset.
If problems still persist, hook up a code reader (Durametric or equivalent) and trace fault.
2001 MV Agusta F4.
