Old 11-17-2013, 09:58 AM   #1
thom4782
thom4782's Avatar
Nope...you'll need to lock the cams in place. Follow the 1st part of the IMS replacement instructions up where it tells you how to remove the flange. PS: If you've gone that far, you might as well replace the OEM bearing with an aftermarket one since you'll have done most of the work anyway in getting to the bearing.
