Old 11-12-2013, 05:50 PM   #1
coreseller
If it has the code # will take it. Sending you a PM.
Edit:
Looked it up, you have to take it to a dealer with a PiWis testing unit, in other words a mess. Thanks and Good Luck.
"If it is like a 2003-2004 986 then there is no user code. There is a code in the radio that matches the code in the instrument cluster. If the codes don't match, such as when you replace a radio, then it will not work. To code the replacement radio you need to visit a dealer with a PIWIS. At least this is they way it had to be done with the 986 CDR-23."
