Old 11-12-2013, 04:47 PM   #2
ganseg
ganseg's Avatar
I believe your front and rear tires are close in diameter to each other. If you go shorter on the rear, you will prob need to go shorter on the front due to stability control expecting them to rotate at similar speeds.
Your speedo is effected by the height of tires. You could check what your speedo reads compared to GPS to determine.
I think you are just fine.
ganseg is offline   Reply With Quote
