Old 02-10-2006, 01:23 PM   #10
denverpete
Originally Posted by rickhuizinga
I have this problem in my 987S 6 speed where I cannot shift from neutral into first gear when rolling (in neutral) above 4 or 5 mph. This is a problem because sometimes selecting second gear isn't an appropriate starting gear when rolling between 5-10mph (especially up hill). Whenever this happens, I have to stop the car, shift to first, then drive on - often pissing off those who are following. If I select 2nd, I have to slip the clutch and bog the engine.
Any suggestions?
Wow, I've only ever seen this problem on Harley's! I have absolutely no problems shifting into 1st (provided the RPM's aren't too high) and I don't see any reason not to. I like to pull up to the corners, downshift into 2nd while braking, then shift into 1st to pull out of the corner. I do notice that it works better if you don't completely let off the throttle.
Giggle. 987S can't shift into 1st. Ah, there's justice in the world after all!
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
