Old 11-11-2013, 07:40 PM   #11
golonaus
golonaus's Avatar
Originally Posted by Bigsmoothlee View Post
Jaay, did you have trouble with the shifter cables being too short when you installed the 3.4 manifold without lowering the engine?
Which 987 engine cover did you use? Was it from a Cayman/Boxster S?
dont know about Jaay,but In my install yes cables are too short
just a bit tho
Simple solution is to move shifter console about 1/2"
I drilled new mounting holes and shifter boot covered it
looks and works as it should
I'm curious how Jaay solved it too, tho
btw
I'm using cover from a cayman s
99' with 3.4l engine. ROW tune. SAI delete
