Old 11-07-2013, 04:32 PM   #2
kjc2050
kjc2050's Avatar
Originally Posted by AKnowles View Post
If you look at the gasket, you'll see a U shaped channel on it. That channel will be compressed when you tighten the bolts and seal the unit. No gasket sealant is required, but you do need to toughly clean the mating surfaces.
Your thoughts about reusing the spring-type hose clamps?
