Old 11-07-2013, 07:32 AM   #1
psquared39
Not considering, I'll assume your location is going to cost you a premium, but - bearings are $40-50, CV joint kits are $80-90. Even if the shop had to replace both joints, including labor they should be able to rebuild the entire axle for about $300. I've done this job on my 02, replacing the inner CV joint and bearing. With the proper tools, its a 4-5hr DIY project.
psquared39 is offline   Reply With Quote
