Old 10-26-2013, 10:13 AM   #6
ybn533
Based on what you said, I think it is the control that has broken, especially if it is not moving properly and the motor is not even coming on to try and tilt the seat back. Perhaps you could test it by removing the control from both seats and connecting the functional seats control to that bad seat and see if it works. If not then it must be the motor.
There is no relay for the seat controls, and a fuse would affect both seats. Here is a diagram of the backrest motor and wiring. The relay and the bit with #2-7, is only if you have seat heaters. Best of luck!
Wow you sure helped me. Thanks.
I'll start with reassemble the seat control and check it. It feels like the button is stuck.
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
ybn533 is offline   Reply With Quote
