Old 10-24-2013, 06:41 AM   #1
mikesz
mikesz's Avatar
Boxster/Boxster S coolant system differences?
I am planning on adding the S center radiator to my 99 Boxster base. Should I also consider replacing the coolant hoses pipes with S hardware? I seem to remember reading the S pipe diameter was larger than the base so I am assuming if I wanted to do this conversion I would have to replace inlet/outlet coolant connections to the engine? I have reviewed the center radiator install on Pedro's Board and Pelican but no discussion regarding coolant lines.
Any thoughts?
99 Porsche Boxster
