Old 10-15-2013, 11:18 PM   #11
Nine8Six
Nine8Six's Avatar
There are a couple methods of detecting failing bearing assemblies that were developed as preventative maintenance practice for factory and shop machines. I am anxious to learn what epapp has to offer the automotive world so I can go buy that 997 I’ve been keeping an eye on!
Detecting rolling element bearing faults with vibration analysis
Using accelerometers or using a broadband pickup and heterodyning for our ears to hear are interesting thoughts but I think would be a challenge on internal combustible engines (with all the other noises and moving parts) but if one could be installed on the IMS bearing cover it might work… OK, I’m off to the lab to develop.
Works on machinery that are heavy, grounded and has a constant rpm. Performing vibration's wave spectrum "analysis" in a dynamic environment (fluctuating rpm being one alone) requires heavily formulated algorithm. Not to mention that the system would need to go through a serious adaptation/learning cycle each time it is boot-up. Your Porsche would cost $150,000 (min) more if it had a such smart system attached to it.
Still cheaper to buy a second hand engine imo
