Old 10-15-2013, 08:17 AM   #1
Nine8Six
Nine8Six's Avatar
Very nice work, impressive in fact! Thank you for the update, I found some clear halogens so now I have to decide if I am up to the task of installing these. After reading your detailed instructions, it doesn't seem too bad.
Thanks Bruce, compliment well received
Have a look at what member Blk986 has written RE opening the headlights. He make it look/sound harder than it really is but regardless, by far The best DYI on the subject anywhere atm. And unlike mine, this one is written in English!!!
http://986forum.com/forums/diy-project-guides/34106-diy-hid-projector-install-instructions.html
All accurate info. Less the wiring set-up. No need for a load-lot-everywhere like Blk986.... (old method) the new ballasts today can simply be connected to the old H7 halogen connector. Just two little wires +/- (black & red). Can't go wrong there
Everything ballast related hides inside the back of the headlight unit. See nothing else but a BOSCH headlight. Clean & easy
