Old 10-14-2013, 12:11 PM   #10
ganseg
ganseg's Avatar
This might be the most complete thread on IMS including part #s of various model years. Feelyx was developing a direct oil feed when his patent was bought out. Lots of good info on bearings and failure modes here.
Who has done an IMS change (New Oil Fed Design Idea) - Pelican Parts Technical BBS
Who ended up selling this design - particularly this aspect:
Post 169: "...What I am developing is a setup that takes the swivel point from inside the shaft, and moves it to outside the case. With my setup, the bearing insert has 2 steps that support the shaft on different levels to make it rigid in the shaft, the bearing is supported in the case halves, where as the original setup, the chains pull on the bearing and shaft (like a lever) causing the inner race of the bearing to deflect and case to flex..."
ganseg is offline   Reply With Quote
