Originally Posted by rp17
Okay I'm sold on the Udp. But whats this about shaving down the boss? Can someone explain? This sounds like a must do for my Fall projects.
The boss sticks out far enough to almost touch the back side of the pulley. The belt surface just wraps around it on orig pulley.
The UD pulley will rub into the boss. It's belt surface is dead even with the boss. So I used a sawzall and cut mine off. It would take a while to file down. Cut off flush or slightly proud.
I do not suggest you use a sawzall unless you are skilled with one. I've been using them for many years.
'08 VW Touareg T-3 wife's car
