Old 10-12-2013, 01:28 PM   #13
Jake Raby
Engine Surgeon
Originally Posted by epapp View Post
Skeptic or not, stick around.
Yes it is arrogant to say real engineering...blah blah blah. We are allow working towards the same goal here, I just have to make myself feel like my solution is better so I will actually build the damn thing.
I will promise one thing: my IMSB health monitoring solution will be conclusive. If I release it, it will be because the data is reasonably accurate and can be replicated.
Once I can judge my IMSB health, I will probably need to crowd source for some more data. Since I don't have 10 boxsters laying around, I'll need a way to gather data of different IMSB healths to make any kind of judgement.
Sent from my iPad using Tapatalk - now Free
Be prepared to force an engine failure under controlled conditions with the system employed. I sacrificed two engines during the development of the IMSG, one of which was specifically built to be killed by installing an IMSB into it that was already at stage 3 IMSB failure.
If you need to gather this data and gather the data I do have these engines in my lab and they are available. Currently one of them is being used for similar research, so a compound test may be possible.
Projections and assumptions don't cut it.
But it wouldn't be cheap.
US Patent 8,992,089 &
US Patent 9,416,697
