Old 10-07-2013, 01:09 PM   #2
thstone
Originally Posted by gavinyuill View Post
I wired mine so that it killed the ECU instead of the ignition. Cant remember which wire it was - I chased it back from the fuse box, but it kills the engine dead.
I have the same switch in my Spec Boxster.
Wiring the power cutoff switch direct to the ECU is important because this is the only way to be sure that the fuel pump will immediately be turned off. Turning off the engine but leaving power to the ECU will leave the fuel pump powered and pumping - not a good thing in an emergency situation.
