Old 10-03-2013, 11:48 PM   #7
Touch The Icon
Touch The Icon's Avatar
Using the oem lugs is not advisable - even with just a 5mm spacer ! You definitely need longer bolts; especially if you increase the size of the spacer to 10mm's. The length of the oem bolt is 28mm's. In order to calculate the correct size bolts, simply add the thickness of the spacer to the length of the oem bolt (s). For example, a 5mm spacer will require a 33mm bolt and so on. Do not continue to drive with the current set-up you have !
Thank you for the advice Johnny! I am officially spooked and not driving my car until I get that fixed this weekend. Pulling out the Commander tomorrow, the Hemi is always fun.
Touch The Icon is offline   Reply With Quote
