Old 10-03-2013, 07:00 PM   #14
Johnny Danger
Johnny Danger's Avatar
Originally Posted by Touch The Icon View Post
Gonna wash her up tomorrow and I will post some better pics. I think the back can use another 5mm, not sure about the front yet. Used the same lug nuts but if I go 10mm I will need longer ones.
The ride is a little more bumpy but its handeling well. Gonna have them recheck the balancing.
Using the oem lugs is not advisable - even with just a 5mm spacer ! You definitely need longer bolts; especially if you increase the size of the spacer to 10mm's. The length of the oem bolt is 28mm's. In order to calculate the correct size bolts, simply add the thickness of the spacer to the length of the oem bolt (s). For example, a 5mm spacer will require a 33mm bolt and so on. Do not continue to drive with the current set-up you have !
