Old 10-01-2013, 12:42 PM   #11
thstone
Hmmmm,
Tom is your gas tank still vented or did they just terminate all the vent tubing when emission stuff was removed? It sounds like you may be pulling a vacuum on the tank as gas is used, causing the fuel pump to cavitate. One possibility at least.
Sounds like a nice day at the track. I suspect your BSR will soon be in 1:36 territory.
Tank is still vented using the stock system in order to pass emissions test and remain street legal. Agree that lack of vent could create a vacuum and result in symptoms that I am seeing. Will investigate.
BTW: Goal is to get into the 1:34's.
