Old 09-29-2013, 05:13 PM   #2
sweeper
sweeper's Avatar
Just a suggestion
I recently had some font body work done on my car- (97 Box- base- Halogen lights) when I got it back from the Body shop everything worked well (Except) the passenger side signal/backlight parking light on the front right headlight. The headlight itself worked fine- high/low etc.
Rather than rushing back to the body shop I pulled the headlight out and checked the "plug and play" socket and it was out of its holder- I snapped it back in place and the problem was solved. It was not making a "complete" connection.
Check to make sure it is installed correctly- should slide in and lock in place smoothly- I always use dielectric grease on the electrical connections as well.
Good luck!!
1997 Boxster- 28k, de-snorked, de-baffled, RSS UD, Dansk "hotdog" sport exhaust.
1985 BMW 635CSI- 30k, 5-speed, LSD
sweeper is offline   Reply With Quote
