Old 09-27-2013, 04:09 PM   #16
Perfectlap
Perfectlap's Avatar
No, it is a special shaft and triple row ceramic bearing assembly that can only be done while the engine is apart. The plain bearing "Solution" only comes in the single row bearing size, uses a pressurized oil feed off the filter out line and has no moving parts whatsoever, and can be retrofitted to an assembled engine.
so why do the former? does this special shaft prevent other types of failure?
BORN: March 2000 - FINLAND
