Old 09-26-2013, 07:14 AM   #12
jesseborgelt
Slap shifter into neutral &/or press clutch pedal to the floor?
See the wheel rim break off leaving the center bolted in place?
I had to watch it again after you mentioned the wheel breaking. That is not something you see often!
If I crashed a car and was embarrassed I would probably blame some mechanical part of the car too. If the throttle was stuck, wouldn't you continue to hear the engine rev? It appears to decrease prior to hitting the wall. Compare the WOT sound of him coming out of the corner to just prior to the "oh crap moment" when impact is unavoidable. It sounds like he let up prior to impact.
Last edited by jesseborgelt; 09-26-2013 at 07:15 AM. Reason: cant say ****************
jesseborgelt is offline   Reply With Quote
