Thread: Coolant leak
Old 09-25-2013, 05:53 PM   #1
Steve Tinker
Steve Tinker's Avatar
When the coolant has been low and the temp guage spikes up even after topping off, its a classic example of air pockets in the system and not a failed thermostat (though it could also be suspect on an older car). If your pump is leaking, I would not run the car untill it has been replaced - M96 engines are susceptable to high temperatures....
Use the search function for water pump failures / installation procedures - you will be reading for quite a while.
2001 MV Agusta F4.
