Old 09-24-2013, 11:01 AM   #20
southernstar
I must say that I am in complete agreement with Perfectlap on this. Lets look at this in context: The problems themselves happened in only 8 % of cars with single-row bearings and less than 1% in cars with double-row bearings. Keep in mind that this is regardless of mileage, age and maintenance schedules - and that it seems clear that cars with frequent oil changes are much less likely to have a failure. If despite what are pretty good odds at avoiding failure on all cars (and exceptionally good on dual-row bearing IMS cars with frequent oil changes) you are still worried, then pay for an upgrade and/or or the LN 'solution, or DOF. Considering the relatively low cost at present for 986's and early 987's, for many it will be relatively cheap, but worthwhile insurance to take into consideration when you buy the car. At least this is a problem that is predictable (and most mechanical problems on cars cannot be predicted with any certainly as no stats are available from the manufacturer); it is also a problem for which there are fixes available.
Brad
southernstar is offline   Reply With Quote
