Thread: Wheel spacers
Old 02-03-2006, 05:32 PM   #1
bmussatti
Guest
Posts: n/a
Originally Posted by insite
if you choose to go for 5mm spacers (47mm offset), you can use the stock bolts. this will save you about $120. i got my spacers and bolts from ********************************.com. if you get new bolts, you will have to remove the cones from your old bolts and put them on the new ones (a pain).
I disagree with this advice. If you use a 5mm spacer, you need to have wheel bolts that are also 5mm longer (part # 996 361 980 02)!
