Old 09-20-2013, 07:27 PM   #33
Timco
I am my own mechanic....
Timco's Avatar
If your vehicle came equipped from the factory with Litronics, then I would presume that it has the additional leveling feature that could only be installed at the factory at the time of manufacture.
Otherwise, your vehicle has an over the counter Litronics set that was installed by the previous owner. As I mentioned, those kits came with a control module that was designed to rotate the low beams a certain degree in order to help fill in the high beams when activated. Since the net effect of this module is marginal to a lot of owners, many didn't even bother installing it.
Yeah, I've got factory Litronics. Seems like the Porsche light is the only light that will work with that feature.
'08 VW Touareg T-3 wife's car
